Browse Forums General Discussion 1 Apr 09, 2021 4:03 am Hi I bought new townhouse 3 years back.since after settlement we have water leakage problem in kitchen. So much damage has occur since 3 years.builder fix it for 7 times still problem is not solved.I am so stressed I have 3 little kids at home and last time when he repair he cut the plaster of wall in half and took all the floor board out for 3 days with nails popping out .I am so not happy with builder work please suggest me what can I do whom should I go to complain? 3 years and still leaking wall I contacted him 10 days back still don't bother to fix please help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water leakage in new townhouse 2Apr 09, 2021 7:07 am Saaj Hi I bought new townhouse 3 years back.since after settlement we have water leakage problem in kitchen. So much damage has occur since 3 years.builder fix it for 7 times still problem is not solved.I am so stressed I have 3 little kids at home and last time when he repair he cut the plaster of wall in half and took all the floor board out for 3 days with nails popping out .I am so not happy with builder work please suggest me what can I do whom should I go to complain? 3 years and still leaking wall I contacted him 10 days back still don't bother to fix please help Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Unfortunately 10 tubes of silicone aren't going to fix your water leak. That flashing needs to be completely replaced and recessed into the render. If I were you I would look for some roofers in your local area and get 3 quotes. Your builder hasn't constructed it properly in the first place and is trying to take a shortcut with the fix. good luck Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Water leakage in new townhouse 3Apr 09, 2021 11:19 am SejaeD Unfortunately 10 tubes of silicone aren't going to fix your water leak. Statistically, a few cartons of mastic goes into every home. I suppose without a building regulating authority it's " DO YOUR BEST, MASTIC THE REST .." (Humour) Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Water leakage in new townhouse 4Apr 11, 2021 7:50 pm If you call your insurance company they might investigate the cause of leak and damage for free and then you can ask builder to fix to code. (My insurance company investigated cause of leak, as they said we won’t fix the paint/floorboards etc unless you have the cause fixed. For me this was helpful as I was able to make sure buider didn’t just patch.) If your buider won’t fix you may be best to pay to get it fixed as per SejaeEd’s advice. Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 14164 if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 3084 |
