Browse Forums General Discussion 1 Apr 02, 2021 12:22 pm Hi, I am looking at doing a detached duplex development, but was trying to seek some information about the minimum distance requirements between the two dwellings under the SEPP. What I would like to build is a duplex like this one (https://hotondo.com.au/new-home-designs/aon-garage-265/) but with the garage separated rather than connected. The SEPP states that the two buildings comprising the dual occupancy (detached) must be located at least 3m apart - 3B.13(3) of the SEPP. However, 3B.49 of the SEPP enables a detached development that relates to a dual occupancy can be built to the 1 or both site boundaries if the building wall is masonary and does not have a window or door for a maximum of 10m in length. While detached duplexes do not appear common, I have seen a number of examples of detached duplexes where the buildings appear quite close to each other: https://www.realestate.com.au/sold/prop ... -132389638 https://www.realestate.com.au/property/ ... t-nsw-2166 Any thought or anything I may have missed would be greatly appreciated. Re: Detached duplex - distance requirements 2Apr 14, 2021 6:41 pm Hi MG7 I'd say to call your council and ask, as each one will have different requirements. Generally, obtaining the minimum block width and block size by square metre should be good enough, as that'd factor the max setbacks. Re: Detached duplex - distance requirements 3Apr 14, 2021 7:24 pm 3m under SEPP. 3B.49 is applicable to detached development (other than the duplex (incl. Garage) itself)which is described under 1.5 Interpretation. Those examples are DA pathways where zero lot is allowed in some council DCPs, both of the samples are methods to maximized lot based on the needs of the driveway locations. SEPP pathway would eaten the design too much I don't mind DA pathway, coincidently we received council approval in 25 days (Record!) for something similar what you wanted, dm for more info Found the answer. The recommended distance is .... 1 5970 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11035 Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12406 |
