Browse Forums General Discussion 1 Mar 31, 2021 9:14 pm I have a couple of issues with an exposed aggregate driveway I recently had put in, and was looking for any advice. For the first question, the concrete was originally very underexposed, so the guys came back and tried to rectify the issue with a high pressure house. It looks better than it did, but it still doesn't look right to me. It's quite patchy, with some areas still underexposed and a couple of patches where the stones have dislodged. The photos aren't great, but I'd really appreciate any feedback on whether there is an issue, and how (or if) this could be improved? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The second issue is that they did different segments of the driveway on different days, which is very obvious (see below). I just wanted to check whether there was any way to help with this ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A final question is whether it's standard to have exposed aggregate washed and sealed after it is put in. I had assumed it was, but it wasn't explicitly in the contract and am starting to think I may have been wrong on this. Some other work this company did at my place was great, and the guys on site were good guys and hard workers, but it just seemed the driveway got a bit away from them. At this point I just want to have as much info as possible before I have another chat to the owner. Any advice would be very much appreciated. Re: Exposed aggregate driveway issues 3Mar 31, 2021 10:00 pm The exposure is definitely patchy. It's a bit hard to make out from the pictures exactly what it is like all over. Did they wash off the same day or the next day? Exposed agg should be acid washed and sealed as part of the price. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Exposed aggregate driveway issues 5Mar 31, 2021 11:22 pm Yeah, that is definitely a bit patchy. The guys I do formwork for wash off the same day but they still apply retarder, although they only have to give it a light spray because they are washing early using low pressure and broom. It typically gives a lower level of exposure that is more bare foot friendly. It should still be even all over. Many guys use a heavy coat of retarder and then pressure wash the next day. That normally gives a deeper level of exposure, which some people like but is far more course. The final acid wash cleans the stones of any cloudiness and loose dust and then the sealer brings up the colour of the stones and concrete. If the exposure is too patchy you can ask to have it sand blasted which will expose everything more, it's the last resort to save under exposed concrete. If they have let it go too far without using a retarder that would explain the under exposure. If they then tried on the same day with a high pressure washer the concrete would be to soft and if they weren't very careful you'd end up with over exposure. That kind of looks like what might have happened but without knowing the exact procedure I'm only guessing. Have they acid washed yet? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Exposed aggregate driveway issues 6Mar 31, 2021 11:52 pm They used the high pressure hose a few days after it was initially laid. Otherwise your guess right, in trying to fix the issue its gone from being mostly under-exposed to a mix of both under and over. I need to chat to them about the acid wash and seal. I left a message the other day asking whether it will be done, but they haven't got back to me. At this stage I don't think they have any intention of doing it. Re: Exposed aggregate driveway issues 7Apr 01, 2021 12:08 am You can't high pressure concrete a few days after. It's basically set off by them. Maybe they tried to sand blast it? Where are you located and how much per M² if you don't mind me asking? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Exposed aggregate driveway issues 8Apr 01, 2021 12:44 am chippy You can't high pressure concrete a few days after. It's basically set off by them. Maybe they tried to sand blast it? Where are you located and how much per M² if you don't mind me asking? That's possible. He said it would be pressure washed, but I was out of town when the correction was done and only saw it a few days after, so it's possible it was sandblasted instead. And no problem. I'm in Brissie and it was $150/m2+gst Re: Exposed aggregate driveway issues 10Apr 01, 2021 12:57 am At $150 M² it should most definitely be acid washed and sealed. How many M² was the pour? Was it the same person who did the other work in your pictures? Half of it looked cleaned and sealed with an even level of exposure, basically what you should expect. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Exposed aggregate driveway issues 11Apr 01, 2021 1:12 am Thought so. All up it was around 90m2, including the driveway and a path around the front and side of the house. I think the driveway alone was 60m2. And it was the same person that did the whole job. In some of the photos it looks like the second batch of concrete (which is much more even) is sealed, but it hasn't been. Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10404 After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly… 0 3572 2 637 |
