Browse Forums General Discussion 1 Mar 23, 2021 1:43 pm I have a laundry tap that is installed on a laminate benchtop. I believe the laundry tap may have moved a little during use over the last few years and, per the photos below, you can see that some of the hole is visible. What are my options for fixing this? It is a standard gooseneck mixer tap. Can I go underneath and loosen something that will allow me to reposition it so it is centred over the hole? I’ve never installed anything like this so not sure exactly how it all works so appreciate any suggestions. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hole for laundry tap is too big - what to do? 2Mar 23, 2021 3:03 pm You can undo underneath the bench and reposition the tap and then retighten. There are different methods used by different manufacturers so you will just have to try and see how to undo it. Usually a Phillips screwdriver but some use different size nuts. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4468 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18821 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7399 |
