Browse Forums General Discussion 1 Mar 20, 2021 3:37 pm Hello, Please look at the pic attached and could someone please shed some light on how this little pipe works, where the water comes from please. Normally small drips of water come out intermittently but now water is flowing out for up to 2 minutes at a time. Then nothing for ages , maybe a day or 2. Then another big flow of water. I have emailed the builder and am waiting for a response. Any ideas? Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: 2 year old 2 storey, home water overflow question 2Mar 20, 2021 4:10 pm Do you have R/C ducted air con? If so that is, I believe, the secondary drain for your air con and if water is coming out of there it means your primary drain is blocked and you're in danger of doing some ceiling damage. Best get an air con service done ASAP Re: 2 year old 2 storey, home water overflow question 3Mar 21, 2021 9:30 pm I agree, if you have ducted A/C then it looks like it could be the condensate drain from the indoor unit. Ours has two pipes, one appears to be a main drain connected directly to the indoor unit itself and there also seems to be a secondary drain from a drip tray located under the indoor unit in the roof... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9530 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10181 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6181 |
