Browse Forums General Discussion Re: Defect advice 2Mar 19, 2021 6:35 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Defect advice 15Mar 22, 2021 5:22 pm Added some more photos to the folder with a level on the skirting boards, also noticed the rear sliding door frame is very badly warped. It out by around 10mm I've tested my water pressure its 350KPA at the garden tap which is the first thing after the mains. Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11234 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5339 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10149 |
