Browse Forums General Discussion 1 Mar 04, 2021 1:20 pm My block of land is raised from the street and has a upslope driveway I want to know if I can level everything, or dig out the driveway, excavate a lower level driveway etc... Can anyone help direct me to the right people/organisations I should speak with to determine what's possible? Re: Planning to rebuild 2Mar 08, 2021 9:18 pm Tenbatsu My block of land is raised from the street and has a upslope driveway I want to know if I can level everything, or dig out the driveway, excavate a lower level driveway etc... Can anyone help direct me to the right people/organisations I should speak with to determine what's possible? it really depends on your local council's requirements, unless your in NSW and using CDC, but councils cut and fill maximums are generally between 600mm and 1000mm. Best to check with a planner at your local council or a building designer familiar with your local area Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Planning to rebuild 3Mar 09, 2021 8:01 am SejaeD Tenbatsu My block of land is raised from the street and has a upslope driveway I want to know if I can level everything, or dig out the driveway, excavate a lower level driveway etc... Can anyone help direct me to the right people/organisations I should speak with to determine what's possible? it really depends on your local council's requirements, unless your in NSW and using CDC, but councils cut and fill maximums are generally between 600mm and 1000mm. Best to check with a planner at your local council or a building designer familiar with your local area Thank you very much! Re: Planning to rebuild 4Mar 09, 2021 9:03 am Tenbatsu SejaeD Tenbatsu My block of land is raised from the street and has a upslope driveway I want to know if I can level everything, or dig out the driveway, excavate a lower level driveway etc... Can anyone help direct me to the right people/organisations I should speak with to determine what's possible? it really depends on your local council's requirements, unless your in NSW and using CDC, but councils cut and fill maximums are generally between 600mm and 1000mm. Best to check with a planner at your local council or a building designer familiar with your local area Thank you very much! no problem, happy to assist where I can. have a great day Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 9149 I am not based in Victoria however i had a quick look into your question to understand what you were asking. The way I read the regulations, overshadowing relates to the… 1 1223 6 22655 |
