Browse Forums General Discussion 1 Mar 02, 2021 10:20 am G'day All, I am been searching around in this forum and Mr.Google but still can't find an answer for my question so posting it here to seek your thought. I have a lot in Merrylands, Cumberland council NSW, my lot is 495m2 with 15m frontage. Without considering the average setback from the primary road of the 2 nearest dwelling houses, which rule should I follow? Cumberland DCP (Holroyd Development Control Plan 2013): The minimum setback from the principal street frontage is 6 metres or , SEPP Housing code: 4.5m for lot size from 300m2-900m2. Thank you, Re: Setback rule: Cumberland Council DCP vs. SEPP Housing co 2Mar 02, 2021 9:54 pm Duo2 G'day All, I am been searching around in this forum and Mr.Google but still can't find an answer for my question so posting it here to seek your thought. I have a lot in Merrylands, Cumberland council NSW, my lot is 495m2 with 15m frontage. Without considering the average setback from the primary road of the 2 nearest dwelling houses, which rule should I follow? Cumberland DCP (Holroyd Development Control Plan 2013): The minimum setback from the principal street frontage is 6 metres or , SEPP Housing code: 4.5m for lot size from 300m2-900m2. Thank you, Its up to you , DA or CDC , then you choose applicable controls. Either way, its a common requirements to both pathways averaging existing neighbours setbacks. But if you have a unique situation and need to work with minimum front setbacks, then DA is best to vary the control. You can call council to speak with duty planner, they will be able to provide guidance on this. Re: Setback rule: Cumberland Council DCP vs. SEPP Housing co 3Mar 03, 2021 5:38 pm Thanks heaps HaminZa. Just in general, which one prevails? SEPP/housing code or LEP/DCP? HaminZa Duo2 G'day All, I am been searching around in this forum and Mr.Google but still can't find an answer for my question so posting it here to seek your thought. I have a lot in Merrylands, Cumberland council NSW, my lot is 495m2 with 15m frontage. Without considering the average setback from the primary road of the 2 nearest dwelling houses, which rule should I follow? Cumberland DCP (Holroyd Development Control Plan 2013): The minimum setback from the principal street frontage is 6 metres or , SEPP Housing code: 4.5m for lot size from 300m2-900m2. Thank you, Its up to you , DA or CDC , then you choose applicable controls. Either way, its a common requirements to both pathways averaging existing neighbours setbacks. But if you have a unique situation and need to work with minimum front setbacks, then DA is best to vary the control. You can call council to speak with duty planner, they will be able to provide guidance on this. Re: Setback rule: Cumberland Council DCP vs. SEPP Housing co 4Mar 11, 2021 5:58 am Duo2 G'day All, I am been searching around in this forum and Mr.Google but still can't find an answer for my question so posting it here to seek your thought. I have a lot in Merrylands, Cumberland council NSW, my lot is 495m2 with 15m frontage. Without considering the average setback from the primary road of the 2 nearest dwelling houses, which rule should I follow? Cumberland DCP (Holroyd Development Control Plan 2013): The minimum setback from the principal street frontage is 6 metres or , SEPP Housing code: 4.5m for lot size from 300m2-900m2. Thank you, Duo2 CDC and DA are totally different pathways. With a DA your approval is via Council, and CDC is via a private certifier. Not every property is suitable for CDC in fact some properties cant use the CDC pathway. So before you decide which route you will take you need to order a 10.7 certificate from your council and that will tell you whether the CDC via the General Housing Code Sepp is applicable to your site. In my opinion the general housing code can be a challenge to interpret sometimes. So its best to talk to an expert. I can also refer you to an expert based who can tell you definitively what setbacks, front, side and rear, and FSR apply) Just let me know Cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Setback rule: Cumberland Council DCP vs. SEPP Housing co 5Mar 27, 2021 7:39 am Hi Duo2, Forgot to respond. SEPP/CDC prevails and will overide all DCP controls. I also concur with above comment. The process suggested will confirm also which pathway and site control best for your property. I am one of the 'experts' who does this day in day out in your Council. Am in the forum to guide homeowners when I can. Good Luck! This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3677 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 |
