Browse Forums General Discussion 1 Mar 08, 2021 1:13 pm Re: VJ Paneling for bathroom rennovation 2Mar 08, 2021 2:42 pm We used it above the tiles, from 2400 to ceiling which sloped. Use the fibro version not the mdf version, it will swell in a wet area. As to using over tiles that would be a bad idea, most bathrooms have hidden issues like rot and waterproofing, always better to strip back to studs if you can. Re: VJ Paneling for bathroom rennovation 3Mar 08, 2021 2:48 pm Pulse We used it above the tiles, from 2400 to ceiling which sloped. Use the fibro version not the mdf version, it will swell in a wet area. As to using over tiles that would be a bad idea, most bathrooms have hidden issues like rot and waterproofing, always better to strip back to studs if you can. Thanks for the reply. Will use the Fibro version. Take your point about the rot and waterproofing - makes sense. Not sure if this makes any difference but all our internal walls inc bathroom are block filled. So no timber, studs etc. assume the block is Hebel. VJ Paneling for bathroom rennovation 4Mar 08, 2021 8:21 pm Polishcrete Polished Concrete Thanks for the reply. Will use the Fibro version. Take your point about the rot and waterproofing - makes sense. Not sure if this makes any difference but all our internal walls inc bathroom are block filled. So no timber, studs etc. assume the block is Hebel. ahh ok, if the tiles are sound you might be able to go over it with appropriate surface prep Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6065 Hi Geoff Install Puddle Flange prior to any screed. Puddle flange needs to be flush with the surface so you may need to grind away the surface to achieve this. Also as… 2 8374 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10380 |
