Browse Forums General Discussion 1 Feb 23, 2021 2:58 am After some opinions of people who have experienced , or who have installed geothermal cooling ( either hydro pipes underground, or air pipes underground? ), for concrete slab cooling / heating and Air / Air exchangers..... In particular Does it work in the dead of summer or winter ? Nick Re: Geothermal heating / coooling thoughts 2Mar 05, 2021 11:00 am Opinions without data and proofs are worthless, ie Opinions can't be used for compliance and certification For energy track down an environmental engineer and do simulations on your House I have concluded in WA (Moderate Climate) it's a waste of money here Ground Temperature recovery systems BTW, Nobody cares about thermal (Breaks) when your slabs breaking up. OT, You are better off investing in making sure your house doesn't move on reactive soils Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Geothermal heating / coooling thoughts 3Mar 06, 2021 12:50 am ![]() Opinions without data and proofs are worthless, ie Opinions can't be used for compliance and certification For energy track down an environmental engineer and do simulations on your House I have concluded in WA (Moderate Climate) it's a waste of money here Ground Temperature recovery systems BTW, Nobody cares about thermal (Breaks) when your slabs breaking up. OT, You are better off investing in making sure your house doesn't move on reactive soils Cheers Chris Yep, I came to the same conclusion regarding the Geothermal. We have room for about 8KW of solar panels, and can insulate as much as needed during the build which can cut down the need for geo in the first place. Thermal breaks were more for the balcony connection to the house not the slab - since balcony faces west it's going to get hammered in the summertime. Our initial rating was 6.5 Star, without any optimizations. Apparently should be fairly easy to get up around 8. 3 1359 This happens a lot! I would have a small timber fence panel made up to close the gap, BUT installed so that is can be removed. You will get a lot of rubbish, leaves, dirt,… 3 1981 Hi all, Have a really steep staircase with some low hanging beams which we'd love to remove in some way to make the stairs much more useable. Any thoughts on what could… 0 1861 |
