Browse Forums General Discussion 1 Feb 17, 2021 9:51 am Hi All, Before posting, i did try to get some information around this but to no avail. Looking for suggestions. We are getting handover in the next 2 weeks >> Driveway and landscaping to commence soon after. Our concreter suggested if we are able to extend the driveway (marked in RED) in the pic VS the original driveway which is narrower towards the road. - How do we go about this change? Is it ok to just extend and will pass the OC? - Do we submit a revised minor amendment plan? Who can assist in doing this to comply? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ - Original plans were sumitted through CDC. - Land is in the Camden Council NSW area. Re: Minor Changes to Driveway size before Occupation Certifi 2Feb 17, 2021 10:02 am You are placing the crossover on council property and they will check for compliance upon completion If it's non compliant you will be forced to rip it up...resubmit plans goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Minor Changes to Driveway size before Occupation Certifi 3Feb 17, 2021 10:12 am ![]() You are placing the crossover on council property and they will check for compliance upon completion If it's non compliant you will be forced to rip it up...resubmit plans goodluck Thanks structuralBIMGuy Appreciate the input. Incidently my concreter just called up a min ago and mentioned the same thing. ![]() Before pouring of concerete, the inspector would either decline but most likely should not be a problem. Builders always submit plans to comply to the minimum requirement i've heard. Fingers crossed, however will ring up council etc prior to any work. Noticed some of photos don't really show mortar cracks very well, so see below for some closer photos. 1 732 Ideally, it should not. Check with your building surveyor, they issue the OC so should be able to clarify. You may also refer to you build permit if there is any note on it. 1 1120 Hi guys, Our footing report came back with an exceeding of $6,000 because our builder said they found fill on the site and request a compaction certificate, without that… 0 480 ![]() |
