Browse Forums General Discussion 1 Feb 13, 2021 5:04 pm Hi guys, I've got an existing hole on my external brick wall for the rangehood vent (pic below). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'll be replacing my rangehood, and hence the ducting and the metal box within the hole will be removed and replaced with new ducting. I will also be buying a new vent to cover the existing hole, like the one below: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The problem is the dimension of the new vent doesn't completely cover the existing hole. i.e. the hole is bigger than the vent.. How should I fill the 'gap'? Should I mortar to make the hole smaller? If so, how do I mortar the top? I imagine gravity will want to make the mortar fall before it has a chance to set? Thanks in advance! can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4423 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 17855 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10185 |
