Browse Forums General Discussion 1 Feb 13, 2021 6:04 pm Hi guys, I've got an existing hole on my external brick wall for the rangehood vent (pic below). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'll be replacing my rangehood, and hence the ducting and the metal box within the hole will be removed and replaced with new ducting. I will also be buying a new vent to cover the existing hole, like the one below: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The problem is the dimension of the new vent doesn't completely cover the existing hole. i.e. the hole is bigger than the vent.. How should I fill the 'gap'? Should I mortar to make the hole smaller? If so, how do I mortar the top? I imagine gravity will want to make the mortar fall before it has a chance to set? Thanks in advance! 10 1712 ![]() DIY, Home Maintenance & Repair Hi, The time has come to remove this old air conditioner. The house is concrete block with render and a textured surface. I am assuming the repair will mirror how the… 0 1544 Thanks for you reply. I have stormwater lines on my property. The wall we are building will be at the fenceline boundary. The ag lines will run on the neighbour (higher… 2 2227 |
