Browse Forums General Discussion 1 Feb 09, 2021 10:34 am Hi all, I have a 3.5 x 3.5m bedroom with a 3.5kW split system air con. There is a tiny room next door to this (3.5 x 1.9m) which I would like to use as a home office if it could be cooled to a comfortable temperature. Is there a way to put a vent or something between the two rooms so the little room can be cooled? It’s a stud wall with VJ. Temperature regulation doesn’t need to be perfect - just need some of the cooled air to be able to waft in! Tempted to just punch a hole in the wall but I’m sure there’s a more elegant solution. Would really appreciate any advice on what to do and who to contact to get it done. Thanks Re: Cooling a room next to an air conditioned room 3Feb 09, 2021 4:41 pm No, they both open into a hallway Re: Cooling a room next to an air conditioned room 4Feb 09, 2021 6:04 pm heat transfer fan https://www.pureventilation.com.au/prod ... sfer-kits/ i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16010 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20183 Did you know that you can get rugs made from carpet? So much cheaper than buying a shop rug. So many styles to choose from, but you won't get the highly patterned… 0 6277 |
