Browse Forums General Discussion 1 Feb 09, 2021 9:17 am Had this plan approved but having second thoughts about about the study in between bed 1 and the walk in robe and ensuite. The mbroom is at the rear of the house and faces North. The idea was to allow the study space to be opened up to the front of the house during daytime and have a mini kitchen in the corner for coffees. The study opens up to balcony with district views and faces due north. Wondering if I should get rid of the wall between the bedroom and the study and build a stacking door instead? Or perhaps a pocket door at the top of the stairs to enter the study area? Or get rid of the study area altogether and have it as a large private master bedroom? Ideas appreciated Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with master bedroom layout 2Feb 09, 2021 1:51 pm Are you using all the upstairs bedrooms for kids? Who is going to be the main users of the study area? Re: Help with master bedroom layout 3Feb 09, 2021 1:53 pm bestspecials Are you using all the upstairs bedrooms for kids? Who is going to be the main users of the study area? Main users will be ourselves... Figured having North south flow might help with cooling breezes.. But thought it would be a clever use of the space if it was dual purposed Re: Help with master bedroom layout 4Feb 09, 2021 3:15 pm Not knowing the age of the other people in your house, I have had a play with the plans. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You could then put bi-fold doors onto the study and it is separate from the master bedroom but can be closed off too. Bedroom 2 then also has a view of the back and can either have access or no access to the balcony (depending on where you put the window or glass door.) Re: Help with master bedroom layout 6Feb 10, 2021 10:11 am Sorry, didn't realise you had already started the build. Might make it difficult as the framing would have already been ordered. Re: Help with master bedroom layout 8Feb 11, 2021 9:49 am chatty It's double brick construction so they haven't started on walls yet... Good luck with whatever you do. I am sure it will look great. Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14283 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7773 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15610 |
