Can anyone point me to some good online resources comparing costs for building in different materials. For example:
- Brick Veneer vs Cladding
- Tiles vs Colorbond roof
Thanks
Browse Forums General Discussion Re: Build Material Cost Comparison 2Feb 08, 2021 8:58 am Hey Coops007 Welcome to the forum It helps if you put up your location and what stage you are at in the process. ie drawings, 3D Model Quants, data, DA, BA, CDC, variations, Facade renderings ? The more information you put up the better the reply plus it also helps others. Here How to decide without quotes BTW pre Builders Grant the brickmakers were offering 25-30% off their retail prices, now you will be lucky to get 10% off the new increased price. Labour costs and trade shortages are presenting even bigger issues. OT all the data, analysis and comparisons are on line, unfortunately you can only access them with a 3D Bim model and software. A word of caution, make sure your 3B Bim software does more than give you a Realistic facade images/renderings or you might end up with unrealistic prices and $ticker $hock when the engineering comes in later on in the process...ouch Help Building Costs facade Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10604 Different to what others have said but thanks for that insight. 2 5205 Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9688 |
