Browse Forums General Discussion 1 Feb 02, 2021 4:23 pm Hi All, Just starting the process of a knock down rebuild and I am drawing up some plans for a custom design. The block is in a cul de sac with a 10m front setback, As i am the first block where the cul de sac starts to "bowl" I have a curved set back (Shown in the orange line) hence almost all "Kit" homes wont suit my block as all new home are designed for perfectly rectangular or square blocks hence the need to a custom design. Anyway I have sketch this up as was hoping minimal windows facing west (only theater small high rectangle window on ground floor) Block boundary in red and build boundary in orange Thanks for any tips/pointers in advanced Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Floor plan feedback. 2Feb 04, 2021 3:52 pm I like the floorpan although room measurements will define if it all works. I feel the upstairs bathroom toilet area could be redesigned as per the attached, ie toilet moved to end of corridor, bathroom entry flipped and basin put into the bathroom area. This would make the WIR larger and better use of space. Good luck/. https://ibb.co/9wzyzW0 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 62413 having built in different rural locations may i suggest that the house should suit the location and needs to be different from homes in town..eg if you will be working… 9 24341 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 29335 |
