Could someone confirm if the following window lintel and stud installation is correct?
Lintel size is 240mm by 42mm and stud size is 90mm by 32mm. Room height is 3.6m
Thanks
Browse Forums General Discussion Re: Window issue 2Jan 29, 2021 3:55 am Mate you need to be closer than the front door when taking a photo at the rear of the house. take 2 photo's, 1 of each window, standing at about middle of window and probable about 2 - 2.5m out, so the area is question is clearly visible We are Expert Consultant's, and we are here to help. Re: Window issue 3Jan 29, 2021 4:33 pm Hi Thanks for your feedback. I only have these photos which I received from the seller. In general, I observed following with zoom of the original photo 1. Jamb stud is not continuous from the bottom plate to the top of the lintel. 2. There is only single jamb stud for window opening of size 3000mm with a floor height of 3.6m 3. Lintel is installed just below the top plate. 4. Lintel and Lintel trimmer are not span to the same opening I could not find such installation as illustrated on Figure 6.9 (in part) Openinggs of AS-1684-2-2010 Lintel breadth/depth D/2 = 42mm Stud depth D= 90mm The lintel is not extended beyound jamb stud to connect to common stud (in photo case, there are multiple studs) to match as Figure 6.9 (b) Lintel breadth less than or equal to half stud depth The lintel is installed directly below top plate to match Figure 6.9 (e) but there is no secondary jamb stud and jamb stud as shown. Re: Window issue 6Jan 31, 2021 2:57 am Sure. Focusing on the window at the back, as joists are loading onto this lintel and not the other windows: FLW calculated by the distance between the lintel and the next support point, which appears to be the stud wall, divided by 2. Not sure if there's an intermediate beam between these two points, too hard to tell from the photo. If there is, take the distance from lintel to beam and divide by 2. thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16283 2 5939 |
