Browse Forums General Discussion 1 Jan 26, 2021 6:50 pm Hey all, we have only just discovered that builders charge extra to paint a ceiling white, and that the contract specifies one colour throughout. We are about to make decisions over the next week as to where we want to spend on upgrades.. anyone else choose to paint in one colour and do it yourself later? Re: Extra for white ceilings and door trim? 3Jan 29, 2021 1:27 am If you're building with a project builder they will be using (most likely) a cheap base paint. I would suggest if you spending on upgrades upgrade your paint brand. I would stipulate you want a sealer coat + a 3 coat system. Normal is a sealer plus 1 or 2 coats over the sealer. I would suggest you arrange for an inspector (yours) to be allowed to carry out a Pre-paint inspection! obviously this is before any paint goes on the wall, this way you can have ALL plaster/timber defects addressed prior to being covered up. If you get the base right the paint work will look quite good. We are Expert Consultant's, and we are here to help. 7 3006 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39704 I was quoting framing timber sizes from Australian Standard AS1684.4 Table A13 for 2700mm wall heights Tile Roof, single storey. This Australian Standard doesn't refer to… 8 7331 |
