Browse Forums General Discussion 1 Jan 12, 2021 7:50 pm Hi guys, We had a leaking washing machine in our laundry and now we have seen the mould under the floorboards (you can walk under our house, thats where the photos were taken). I am confident there is no water leaking but this mould may wel be growing behind the plaster walls in the laundry. I can easily get the plaster walls replaced but who would I contact to get the tiles ripped up, then replace the actual wooden floor boards affected and then maybe also part of the timber in the walls around it? What sort of tradesman does this? In regards to the mould, who can do a thorough inspections on any mould growth in our house as I want to stay clear from Mould Doctors etc.? Hope someone can advise! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to replace timber floorboards with old mould 2Jan 12, 2021 7:51 pm Nick77 Hi guys, We had a leaking washing machine in our laundry and now we have seen the mould under the floorboards (you can walk under our house, thats where the photos were taken). I am confident there is no water leaking but this mould may wel be growing behind the plaster walls in the laundry. I can easily get the plaster walls replaced but who would I contact to get the tiles ripped up, then replace the actual wooden floor boards affected and then maybe also part of the timber in the walls around it? What sort of tradesman does this? In regards to the mould, who can do a thorough inspections on any mould growth in our house as I want to stay clear from Mould Doctors etc.? Hope someone can advise! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10228 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7755 |
