Browse Forums General Discussion 1 Jan 06, 2021 7:03 am I posted this question on the whirlpool forums and they got me started but I've hit another snag. https://forums.whirlpool.net.au/thread/91jyrjz3 While cleaning my gutters I discovered that my stormwater was blocked below ground. I cleared this and now want to install a pit for easy access. As it is, the pit top will be below ground level. The distance to the top of the horizontal pipe is 50cm https://ibb.co/YdZNYR4 https://ibb.co/dj0tCmK Should I: a: link into the rainwater pit from the bottom b: Use cement to make a lip that goes above ground level c: use pvc curved adapters to raise the level of the pipe and go into the side of the pit d: something else? Many thanks, Ian Re: drainage question 2Jan 07, 2021 10:09 am estaman I posted this question on the whirlpool forums and they got me started but I've hit another snag. And no one advised to simply fit a leaf diverter? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12288 2 5858 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3148 |
