Browse Forums General Discussion 1 Nov 22, 2020 5:16 pm We have a large incline in to a room that needs to be ground down to create a level bench. Have spoken to a couple of companies to do so as well as an engineer and we have been advised under no circumstances do you grind down a waffle pod slab as it will make the surface to thin. It’s been classed as a major defect that means the slab needs to be re poured. Anyone come across this? Re: Grind down waffle pod surface. 2Nov 23, 2020 6:45 am Is this a brand new home? If so, I'd be putting that back on your builder stat! Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9856 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8268 |
