Browse Forums General Discussion Re: Would you lose a bedroom to gain more living space? 11Nov 23, 2020 1:49 pm bestspecials Can I make a suggestion - the Manhattan Two plan would be a better option Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The media room is already in the right place. If you flip the orientation of the room and putter double cavity sliders on the door, you will get the extra light you are looking for by leaving the doors open when you aren't using the room. It could also have direct access to the outdoor area via external sliders. That leaves bedrooms one and three with direct access to the 2nd bathroom and bedroom 2 could then be used as a multi-purpose room (guest room, play room or study). Great suggestion except we have already built and just looking at how we could make adjustments. In hindsight I would have gone with the Two over the One. But yes, this floor plan is essentially what we would end up turning our Manhattan One into. Good idea on the cavity sliders, I hadn’t thought of that Re: Would you lose a bedroom to gain more living space? 12Dec 01, 2020 2:47 pm One thing to consider is if you use the Home Theatre as a bedroom then you no longer have two separate living areas. This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10345 I would be wary. Is you site demilished but nothing else done? Sounds like liquidity problems to me. Our builder did the same. Got hundreds of thousands of dollars of… 2 15401 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8775 |
