Hi anyone know what stage the pilings are installed?
I assumed it was be at the slab stage but it wasn’t and now they have started the brickwork.
See pic below for where they are meant to be installed.
Browse Forums General Discussion 1 Nov 13, 2020 6:30 am Re: What stage are Pilings Installed? 2Nov 13, 2020 8:08 am You will need to go back to the Council and engineer and discuss positioning offset piling hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: What stage are Pilings Installed? 3Nov 13, 2020 9:29 am The piles go in before or with the footings. Have you confirmed that the builder has failed to install them? It looks like you are in WA. Depending on what type and size of pile you had specified you may not hav even seen them get dug and poured if you weren't on site when the footings were poured. Often the grano workers will dig the footings on one day and allow the plumber and electrician to do there pre-lay, then the next day just prior to pouring the footings will clean up the footings and auger out the pile holes. Thats to make sure the holes don't start to collapse over night. If you aren't on site in the hour before they start pouring the footings you may not even see them get dug. I'd confirm with the builder and if they have been omitted then you need to look at BIM guys advice Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What stage are Pilings Installed? 4Nov 13, 2020 11:01 am chippy The piles go in before or with the footings. Have you confirmed that the builder has failed to install them? It looks like you are in WA. Depending on what type and size of pile you had specified you may not hav even seen them get dug and poured if you weren't on site when the footings were poured. Often the grano workers will dig the footings on one day and allow the plumber and electrician to do there pre-lay, then the next day just prior to pouring the footings will clean up the footings and auger out the pile holes. Thats to make sure the holes don't start to collapse over night. If you aren't on site in the hour before they start pouring the footings you may not even see them get dug. I'd confirm with the builder and if they have been omitted then you need to look at BIM guys advice Oh thanks for the reply. I remember asking my inspector at the slab inspection pre-pour about the piling and he said it’s installed later. So either he didn’t know what he was talking about or he misunderstood the question. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16145 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 9173 1 4948 |
