Browse Forums General Discussion Re: Cornice on load bearing wall cracked every 600mm or so. 3Nov 08, 2020 10:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Cornice on load bearing wall cracked every 600mm or so. 4Nov 08, 2020 12:57 pm aussieta post some photos rephrase your description, if cracks were 600mm wide you could climb through them Sorry I’m very new to this, as you can probably tell haha, I meant the cracks appear every 600mm. Re: Cornice on load bearing wall cracked every 600mm or so. 5Nov 08, 2020 12:59 pm building-expert It is most likely your house has a truss roof and the wall with damaged cornice is internal non load bearing wall. If you have slab heave or edge subsidence then bottom chords of trusses are pressing on the cornice. I have seen this many times however you have not provided sufficient details. If you want right answers and what to do about it you should invest in proper inspection and a report Thank you. I have just arranged a structural engineer to inspect and report. Re: Cornice on load bearing wall cracked every 600mm or so. 6Nov 08, 2020 1:04 pm aussieta post some photos rephrase your description, if cracks were 600mm wide you could climb through them Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cornice on load bearing wall cracked every 600mm or so. 7Nov 08, 2020 1:30 pm i think building-expert is on the money with the trusses being the issue what is the roof story, colourbond, tiles, solar panels is this a new build or been reroofed Re: Cornice on load bearing wall cracked every 600mm or so. 9Nov 11, 2020 5:40 pm alexp79 This sounds like a slab heave issue to begin with, roof trusses providing load on a non-load bearing wall is just a consequence. Yes most likely but if one side of the house has subsided it will have same effect. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15456 My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10790 4 6814 |
