Browse Forums General Discussion Re: Rake ceiling costs 2Oct 19, 2020 3:15 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Rake ceiling costs 4Oct 19, 2020 3:28 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Rake ceiling costs 7Oct 19, 2020 6:33 pm mishsy SejaeD mishsy How much more expensive is it to have rake ceilings? We are building in steel. We build raked roofs (skillion) for the same price as standard roofs. The extra cost for us comes from the upgraded air conditioning. We have found that It's very hard to run ducted air conditioning through a raked roof as there is no room for the 300mm ducting. Therefore the cheap option is individual split systems or we can go a full commercial style VRV system which costs around $20k more. These are similar to hotel suites where every room can be controlled individually. hope that helps Thanks heaps for the advice! 👍 We aren’t installing any air conditioning so that won’t be a problem but it is a A frame rake not a skillion is it still the same price yep would be roughly the same unless you want to expose your beams. just wanted to clarify that that is for our company which is sydney based, not sure if companies in other states would want to charge you more, but for us the cost is so marginal that we dont pass it on. hope that helps Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10658 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5900 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2447 |
