Browse Forums General Discussion 1 Oct 15, 2020 7:52 am Hi guys, I am new here. Needed some help/advice. Purchased a this house in nsw a few months ago it is still under 2 year and 6 years warranty. In the picture that I have attached is where heaps of water pools and does not drain. It become extremely muddy an in accessible. I would like to know if this falls on the builder to fix? However, I would also like some advice on how one would go about fixing this and how much it would cost approximately. Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Side of house not draining. 2Oct 15, 2020 8:17 am somethingtofix66 Hi guys, I am new here. Needed some help/advice. Purchased a this house in nsw a few months ago it is still under 2 year and 6 years warranty. Hey somethingtofix66 Welcome to the forum The structural warranty transfers over to the new owner somethingtofix66 In the picture that I have attached is where heaps of water pools and does not drain. It become extremely muddy an in accessible. I would like to know if this falls on the builder to fix? Get a copy of the certified Stormwater plan, Engineering , geotech report from your local council Unfortunately you wont have access to the Building contract and will need to determine contractually who is responsible for the stormwater. In some Councils it may be mandatory to connect to stormwater drainage systems ,etc,etc Armed with the info then ask questions somethingtofix66 However, I would also like some advice on how one would go about fixing this and how much it would cost approximately. Thanks. First determine what should have been done, then who's responsible The fix will require Drains, pits and concrete perimeter skirt and other solutions. OT, it's wise to always get a structural report and have the slab checked for differential movement, heave,etc before you purchase or make it a condition of purchase. HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Side of house not draining. 3Oct 16, 2020 1:54 am StructuralBIMGuy somethingtofix66 Hi guys, I am new here. Needed some help/advice. Purchased a this house in nsw a few months ago it is still under 2 year and 6 years warranty. Hey somethingtofix66 Welcome to the forum The structural warranty transfers over to the new owner somethingtofix66 In the picture that I have attached is where heaps of water pools and does not drain. It become extremely muddy an in accessible. I would like to know if this falls on the builder to fix? Get a copy of the certified Stormwater plan, Engineering , geotech report from your local council Unfortunately you wont have access to the Building contract and will need to determine contractually who is responsible for the stormwater. In some Councils it may be mandatory to connect to stormwater drainage systems ,etc,etc Armed with the info then ask questions somethingtofix66 However, I would also like some advice on how one would go about fixing this and how much it would cost approximately. Thanks. First determine what should have been done, then who's responsible The fix will require Drains, pits and concrete perimeter skirt and other solutions. OT, it's wise to always get a structural report and have the slab checked for differential movement, heave,etc before you purchase or make it a condition of purchase. HTH Thank you so much! I will be back with an update here. Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12247 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4658 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9202 |
