Browse Forums General Discussion 1 Oct 13, 2020 9:05 am Who owns the stormwater drain that runs from your boundary through the nature strip and out onto the kerb and channel? Does the council own this or is it the home owner? So if it was damaged or blocked would the owner have to fix it or the council? Thanks in advance. Re: Ownership of stormwater drain in nature strip 2Oct 13, 2020 9:32 am I believe you do up to the Sydney Water main line on the road. I had an issue last year where the sewer pipe was blocked under the public footpath outside my boundary and impregnated by roots on my land. Long story short, I paid for my side to be fixed ($4k) and lucky Sydney Water fixed the rest at no cost to me or else I would of bared the cost of excavating the footpath. My memory is vague but at some point a few years ago the rules changed so home owners don't bare the cost of fixing pipes under a public footpath. (Someone else may shed some more info on this) Read this article from 2013. https://www.dailytelegraph.com.au/sydne ... 701bb916ac Re: Ownership of stormwater drain in nature strip 3Oct 13, 2020 7:29 pm The nature strip is owned by the council but it is up to the owner ( in most councils anyway ) to service any pipes that connect to their gutter. I presume by drains that you are talking about a 90mm plastic pipe that takes water from your downpipes to the gutter? Stewie Re: Ownership of stormwater drain in nature strip 4Oct 14, 2020 2:43 am Stewie D The nature strip is owned by the council but it is up to the owner ( in most councils anyway ) to service any pipes that connect to their gutter. I presume by drains that you are talking about a 90mm plastic pipe that takes water from your downpipes to the gutter? Stewie Yes, the 90mm storm water house drain. What if this pipe was damaged by trees in the nature strip that the council had planted many years ago? I'll probably just ring the council for a definitive answer but thanks for the reply. Regards, Mick Hi everyone, Just wondering if anyone has switched from a small square tile insert or normal square waste to a strip drain at all, and if so did the plumber or diy-er… 0 13139 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8467 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7933 |
