Browse Forums General Discussion 1 Oct 09, 2020 10:00 pm I'm looking to attach 3mm thick acrylic to 5mm thick hardwood and am not sure which screw type and size to use. To clarify, I want to attack the long side of the acrylic (not 3mm side) parallel to the 5mm side of the hardwood. Feel free to suggest products obtainable from Bunnings. Re: What screw type should I use to attach acrylic to wood? 2Oct 10, 2020 1:45 am Hi. I assume you mean that you want to attach the acrylic and timber face to face. In which case your screws can be no longer than 8mm or it will go through the timber. Do you need countersunk head or pan head. You can get 4gauge 6mm pan head screws from Bunnings. If you want countersunk you will have to get them from a specialist fixings supplier. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What screw type should I use to attach acrylic to wood? 3Oct 10, 2020 1:47 am aria9521 I'm looking to attach 3mm thick acrylic to 5mm thick hardwood and am not sure which screw type and size to use. To clarify, I want to attack the long side of the acrylic (not 3mm side) parallel to the 5mm side of the hardwood. Feel free to suggest products obtainable from Bunnings. Countersunk screws would be something like this. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What screw type should I use to attach acrylic to wood? 4Oct 10, 2020 9:51 am chippy Hi. I assume you mean that you want to attach the acrylic and timber face to face. In which case your screws can be no longer than 8mm or it will go through the timber. Do you need countersunk head or pan head. You can get 4gauge 6mm pan head screws from Bunnings. If you want countersunk you will have to get them from a specialist fixings supplier. Hello, I was planning to have the head of the screw on the acrylic side, is a countersink screw still appropriate? Also, I want the screw to enter from the 5mm side of hardwood, so my question is more of "is there a screw size that is smaller than 5mm and won't cause the wood to split?" Re: What screw type should I use to attach acrylic to wood? 5Oct 10, 2020 11:27 am Any chance you could do a quick drawing of what you want to achieve. I don't understand how you can have the head on the acrylic side but have the screw enter from the timber side. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What screw type should I use to attach acrylic to wood? 7Oct 10, 2020 2:32 pm A 4 gauge screw is roughly 3mm in diameter and needs a 1.5mm pilot hole. You may have to drill a 2mm pilot hole to prevent the timber from swelling as you screw it in. What exactly are you making out of 5x300 timber? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What screw type should I use to attach acrylic to wood? 8Oct 10, 2020 4:12 pm chippy A 4 gauge screw is roughly 3mm in diameter and needs a 1.5mm pilot hole. You may have to drill a 2mm pilot hole to prevent the timber from swelling as you screw it in. What exactly are you making out of 5x300 timber? It's just an example, the actual dimensions of the timber is 350 x 170 x 5 mm. Thanks for the help, I couldn't figure out how to determine the screw sizes. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 6117 4 7191 Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 2647 |
