Browse Forums General Discussion 1 Sep 28, 2020 6:42 am Hi, Is the crack in mortar a concern? As shown on photo.this is almost 30yo home. Is it necessary to patch, if so, what products are available. I have seen mortarfill and mortar works available and uncertain of which to use. Any other suggestions welcome too. Thanks heaps. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What product to use in fixing cracks in corner mortar 2Sep 28, 2020 7:22 am The cracks indicates, there is a movement and you will have to workout on the root cause and fix it first. I don't knwo about the materials to fix brick crack (probably mortar fill - if you can find the same colour used). our builder fixed the problem for us (warranty period). We had a plumbing leak under ground. Re: What product to use in fixing cracks in corner mortar 3Sep 28, 2020 7:29 pm jay4542 The cracks indicates, there is a movement and you will have to workout on the root cause and fix it first. I don't knwo about the materials to fix brick crack (probably mortar fill - if you can find the same colour used). our builder fixed the problem for us (warranty period). We had a plumbing leak under ground. Thank jay for your assistance and input Re: What product to use in fixing cracks in corner mortar 4Oct 08, 2020 6:33 am I don't think it is a serious problem. It looks to me like one brick wall butts into the other meaning they are not interlocking like you would see on your external corners. You would always get some slight movement and cracking in that instance. Stewie Re: What product to use in fixing cracks in corner mortar 5Oct 15, 2020 10:42 pm Stewie D I don't think it is a serious problem. It looks to me like one brick wall butts into the other meaning they are not interlocking like you would see on your external corners. You would always get some slight movement and cracking in that instance. Stewie Thank you Stewie for explanation and input. Yeah, reckon it is some slight movement ...expected of a build from mid 90s. All fixed now with help of mortar mix. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9565 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4869 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8975 |
