Browse Forums General Discussion Re: Slab heave nightmare. I don't know what to do- please he 3Sep 20, 2020 2:21 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave nightmare. I don't know what to do- please he 5Sep 20, 2020 6:30 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave nightmare. I don't know what to do- please he 8Sep 20, 2020 9:35 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave nightmare. I don't know what to do- please he 10Sep 21, 2020 1:38 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave nightmare. I don't know what to do- please he 12Jan 02, 2021 7:56 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Slab heave nightmare. I don't know what to do- please he 13Jan 02, 2021 12:28 pm SaveH2O "Minor rectification work" will be a short term cosmetic cover up. Did you have slab levels recorded? Re the 'path'...the builder had it installed at a non compliant height (see my prior post) and without a spoon drain or similar. This has allowed water to pool at the path's edge. Also, the 'path' looks like pavers (are they?), is too narrow and not conducive to good drainage. It was a cheapskate effort. Also record the path's depth and how the base was constructed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What direction does most of your rain come from? It has to he remembered that the house wall also serves as a rain catchment when there is a breeze or greater when the wall faces the weather. Their claim that overwatering the turf has caused the problem can be easily refuted by evidence as to when the turf was laid, by your water bills and by your paper trail. Have you had the stormwater and drain (DWV) pipes forensically examined by recorded CCTV? Thank you for your response H20. I appreciate you taking the time. I recently paid $3500 for my own engineering report and I am still waiting on receiving this. The process has been slow due to Christmas holidays etc. The engineer did pick up on the issues with the pathway as you kindly pointed out to me in a previous post. The path is not pavers, it is concrete. Yes, when the engineer did his inspection, he brought a plumber with him that looked through the pipes with a CCTV camera and did not observe any cracking or other issues. He did mention that at a certain join, a "knuckle joint" was supposed to be used but had not been. To be completely honest, I couldn't tell you what direction the rain usually comes from. Thanks again. Re: Slab heave nightmare. I don't know what to do- please he 14Sep 07, 2021 10:19 am Adman SaveH2O "Minor rectification work" will be a short term cosmetic cover up. Did you have slab levels recorded? Re the 'path'...the builder had it installed at a non compliant height (see my prior post) and without a spoon drain or similar. This has allowed water to pool at the path's edge. Also, the 'path' looks like pavers (are they?), is too narrow and not conducive to good drainage. It was a cheapskate effort. Also record the path's depth and how the base was constructed. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What direction does most of your rain come from? It has to he remembered that the house wall also serves as a rain catchment when there is a breeze or greater when the wall faces the weather. Their claim that overwatering the turf has caused the problem can be easily refuted by evidence as to when the turf was laid, by your water bills and by your paper trail. Have you had the stormwater and drain (DWV) pipes forensically examined by recorded CCTV? Thank you for your response H20. I appreciate you taking the time. I recently paid $3500 for my own engineering report and I am still waiting on receiving this. The process has been slow due to Christmas holidays etc. The engineer did pick up on the issues with the pathway as you kindly pointed out to me in a previous post. The path is not pavers, it is concrete. Yes, when the engineer did his inspection, he brought a plumber with him that looked through the pipes with a CCTV camera and did not observe any cracking or other issues. He did mention that at a certain join, a "knuckle joint" was supposed to be used but had not been. To be completely honest, I couldn't tell you what direction the rain usually comes from. Thanks again. Hi Adman, Now I got same issues like you. I built my new house three years ago in Melbourne. I found many cracks on ceiling and wall few months ago. The builder inspected my house and then he said I need to remove footpath and reinstall because it hasn't proper angle according to Victoria building regulations. And then he needs to monitor the house heaving. So I asked him if I replace the footpath, is the slab heaving going to be steady? But he never answered about my question and keeps talking about other things. I'm so frustrated now. I just need a clear solution about my problems. Can you share your situation with the builder at the moment? Now I'm seriously looking for a legal adviser about my issues. Thank you Re: Slab heave nightmare. I don't know what to do- please he 15Sep 07, 2021 12:42 pm If you are interested in my case, there is a MUCH more detailed thread where you can learn about everything that has happened to me and where my situation is up to: https://forums.whirlpool.net.au/thread/3p8n8lx3 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36939 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 3673 Thankyou so much ๐ I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK ๐ 2 7158 |
