Hi,
Could someone please explain to me what this cut/fill line across our house means?
Thanks.
Browse Forums General Discussion Re: What does this cut/fill line mean, please? 5Sep 12, 2020 12:26 pm Stewie D They ( or you ) will need to put some sub-surface drains in to drain away any water. It should be on your plans somewhere. If not, ask. Stewie The plan relating to sub-surface drainage is just a generic plan (it is not site-specific). I don't believe there is any sub-surface drainage around our house. 4 10822 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 In WA zero lot is actually zero lot. We build 10mm in from the boundary. My house and my neighbours house have garages that sit only 20mm apart. When I had our roof done… 3 7067 |
