Browse Forums General Discussion 1 Sep 11, 2020 1:33 am Hi everyone, I have a land width 30m and length 20m and It's a corner plot.The total land area is 572m. I want to build a double story house.Can anyone please recommend me a builder for my land size? I am in Victoria.TIA Re: Advice for 30m wide and 20m length block 2Sep 11, 2020 8:00 am Congratulations on securing the land. Sounds like a good size. We have a similar sized plot here in QLD. Your question is fairly open ended. What you probably need to do is define some specifics before approaching builders. The following might help you in your quest to approach and filter out builders: * visit show homes * have an idea about what you like in styling and decor themes (eg hamptons, traditional, modern, colours) * have a budget in mind (a mortgage broker can work out what you're likely to be able to borrow), this will directly influence everything else you decide cos in the end, it all costs money * try to mock up the floorplan of your house on computer, or copy the layout of a house you like I say the above from experience. Had we not done the above (especially the last two items) before approaching builders, we would have been taken for a ride. Re: Advice for 30m wide and 20m length block 3Sep 11, 2020 9:13 am Try to find a plan that has you living areas facing north. They'll be brighter, & warmer in winter, heated by the northern sun. Try to limit western windows (this is an ideal location for the garage), location bedrooms in the south & east of possible. Orientating a home correctly like this will increase your comfort, & lower your requirements for heating & cooling. Designing a home this way is called "passive solar design". You can read more about it on this brilliant government website, https://www.yourhome.gov.au/passive-design Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25171 Pulse is correct. It's the trap that takes up space. The plan shows a vessel style basin so you don't have to worry about a basin inset, it's just the trap that the… 5 1681 |
