Browse Forums General Discussion 1 Sep 06, 2020 1:48 am Hi all! Just reading through my developer guideline as I go through my siting. It says: Dwellings on lots above 300sqm must have a minimum front setback of 4 metres and a rear setback of 2 metres. Porches, verandahs and porticos less than 3.5 metres in height may encroach up to 1.5 metres into the minimum front setback. Based on my floorplan, I believe I can have my porch encroach .5m into the 4m setback - I was wondering if anyone may be able to confirm this quite easily with the siting plan attached? My understanding is that for as long as the height of the porch is less than 3.5, I can have this encroach max 1.5m to the front set back.. does the height mean the height of the ceiling or something else? If it helps, here's a sample drawing of my façade (based on 2.4m ceiling) - I however opted for a 2.74m ceiling throughout.. I haven't increased the ceiling height of my porch.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I would like to see if my understanding is incorrect - the reason why I want to move the house closer is so that I can have .5m at the back to see if I can extend the house further. Thanks so much in advance. Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15779 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8463 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3677 |
