Browse Forums General Discussion Re: change wall mixers after handover easy? 2Sep 04, 2020 9:41 am In order to change the mixers over you need access inside the wall. You will need to remove tiles first than cut part of the wall so plumber can access the taps in the wall. The issue is mainly waterproofing which is why they say shower is hardest, if you touch or cut the waterproofing than repair it you will more than likely void your warranty. The cost of changing the taps after handover will not be cheap as you will need tiler, Waterproofer, plumber and someone to do wall repair. Most builders should allow you to provide the taps you wont just to be installed by their trades at the time of building, just sweet talk the supervisor. Re: change wall mixers after handover easy? 3Sep 06, 2020 12:36 am Splashers In order to change the mixers over you need access inside the wall. You will need to remove tiles first than cut part of the wall so plumber can access the taps in the wall. The issue is mainly waterproofing which is why they say shower is hardest, if you touch or cut the waterproofing than repair it you will more than likely void your warranty. The cost of changing the taps after handover will not be cheap as you will need tiler, Waterproofer, plumber and someone to do wall repair. Most builders should allow you to provide the taps you wont just to be installed by their trades at the time of building, just sweet talk the supervisor. Thanks so much for your response!!! ill just do the taps via the builder Re: change wall mixers after handover easy? 4Sep 06, 2020 1:20 am elloelloelloqwer Splashers In order to change the mixers over you need access inside the wall. You will need to remove tiles first than cut part of the wall so plumber can access the taps in the wall. The issue is mainly waterproofing which is why they say shower is hardest, if you touch or cut the waterproofing than repair it you will more than likely void your warranty. The cost of changing the taps after handover will not be cheap as you will need tiler, Waterproofer, plumber and someone to do wall repair. Most builders should allow you to provide the taps you wont just to be installed by their trades at the time of building, just sweet talk the supervisor. Thanks so much for your response!!! ill just do the taps via the builder better to go with builder kaagad Follow my build journey here! :-D Re: change wall mixers after handover easy? 5Sep 06, 2020 2:00 am I would rather say it all depends on what type of mixer you are replacing. If mixers are not built into the wall - it is literally 10 min job. For concealed shower or built into-wall mixers it will be as hard as Splashers said above, so better get the right mixers straight away. Re: change wall mixers after handover easy? 6Sep 06, 2020 11:15 am alexp79 I would rather say it all depends on what type of mixer you are replacing. If mixers are not built into the wall - it is literally 10 min job. For concealed shower or built into-wall mixers it will be as hard as Splashers said above, so better get the right mixers straight away. Thank you very much for the advice. My basin mixer is built into the wall so perhaps I should just compromise and work with the builder's range on this one !!! DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41552 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35330 5 10491 |
