Browse Forums General Discussion 1 Aug 30, 2020 12:33 pm Hi all, Have a very slight fall to the rear of property and need pits and pumps to get water to kerb and channel. I want to place a 10000l in front yard so that I can preserve water with only overflow going to kerb and channel if tank is full. Anybody done this in Melbourne? Any companies you can recommend? Thanks Re: Concrete underground water tank Melbourne 2Aug 30, 2020 3:52 pm Michael C Hi all, Have a very slight fall to the rear of property and need pits and pumps to get water to kerb and channel. I want to place a 10000l in front yard so that I can preserve water with only overflow going to kerb and channel if tank is full. Anybody done this in Melbourne? Any companies you can recommend? Thanks You should be able to simply find a competent plumbing company to do this. It's not a specialized job, just needs machinery that is all. Good luck MC Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17611 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10931 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1723 |
