Browse Forums General Discussion 1 Aug 30, 2020 7:04 am Hi Currently at last stages of project home. Need advise if rubber joiner is suitable for charged stormwater line? Will it last? Original pipe had a hole and plumbers used rubber joiner, I assumed they would use a coupling and PVC glue. The area is a foot path which will have concrete poured with next few days. And not sure to request builder to have the join repaired again with glue/coupling. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Stormwater pipe repair before concreting 2Aug 30, 2020 9:47 am It's good. I would never specify the use of flimsy SN2 pvc stormwater pipe in a charged system but it is probably included in the specs. Not impressed with the (lack of) angle of repose either! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater pipe repair before concreting 3Nov 08, 2021 7:41 am @SaveH20 can you confirm that 'it's good' means that the rubber join will last. I did the same thing yesterday with stormwater pipe 300mm lower than outlet to street about to be covered by concrete driveway and concerned this morning it will perish in 30years or less. Re: Stormwater pipe repair before concreting 4Nov 08, 2021 4:36 pm 30 years is a long time but they are used extensively in underground non and low pressure applications. You posting has reminded me that I was going to check manufacturers definition of "low pressure application" to make sure that a rainwater harvesting wet system fell into that category. These days I don't recommend using them with rainwater harvesting wet system pipes but I realise you have a non pressure application. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has… 0 18712 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8280 |
