Browse Forums General Discussion Re: Neighbour Drilled into our Garage Wall 6Aug 28, 2020 9:36 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5498 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7135 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17230 |
