Browse Forums General Discussion 1 Aug 18, 2020 3:29 pm I have a single loose floor tile in my bathroom and am looking at options to repair this. Unfortunately I have no spare tiles so I don’t want to risk trying to lift the tile up and accidentally cracking it. Based on my understanding, there appears to be three options: 1) DIY repair using Fix-a-Floor (or equivalent adhesive) – would involve removing grout, applying adhesive using caulking gun which would then ideally flow into the cavities, and then regrout. Most cost effective. 2) ‘Stickit’ injection system – off the shelf product for fixing loose / drummy tiles. Involves drilling into grout and applying product. Still DIY (seems to be closer to DIY version of Option 3) but probably 3 times more expensive than Option 1. 3) Epoxy injection system – pay for tradesmen to come and inject epoxy adhesive under pressure. Comes with 10 year guarantee, but costs hundreds of dollars. Has anyone had experience regarding this issue and can offer me some advice as to what may be the best approach? Re: Fixing loose tile with no spare tiles available 4Aug 21, 2020 3:45 pm There are tile grout removers available. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A small handheld timber handle and metal shaft ( usually ) with a narrow tungsten carbide blade on it. You rub it back and forth along the grout line surrounding the tile until you are down to the sand/cement mortar level or glue if that's what the tiler used then simply prise up the tile carefully with an old paint scraper. Been there, done that on a few of our renos. Clean off the old glue or whatever on both surfaces and glue it back down. Stewie Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2774 start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 17859 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7620 |
