Browse Forums General Discussion Re: Rainwater tanks 21Mar 09, 2008 9:43 am I think we discussed on the forum with Allan Huang
He was quoted about the same - then went away and broke down the costs and found it was about right. As someone building in an extreme bushfire danger area - we can't go with the cheap poly tanks that Rodda mentioned - they melt! We have a rough quote for an underground 10,000L tank for garden irrigation & fire fighting purposes only (not linked in to toilets or washing machine) for about $7000 (including excavation costs) After 4 years - we're in! Re: Rainwater tanks 22Mar 09, 2008 1:13 pm our 2000l tank cost $1000 (stratco) and the plumber will plumb it to toilets (x3) and laundry sinks. the pump we chose has a 'switch to mains' when it gets low as we didn't want to fill our rainwater tank with mains water, i agree, it seems to defeat the purpose. the pump cost about $900.
Helen Re: Rainwater tanks 23Mar 09, 2008 10:56 pm I definitely don't want my tank filling with mains water, I drink rain water (yes, I know this has been a whole thread before) and I want to know that my tank is rain water not tap water.
I wanted a rainwater tap in the kitchen but apparently builders won't do this as they cannot be held responsible for drinking quality of rain water (state supplier responsible for tap water), I told them to pretend we wanted it for washing up then but answer still no, so we have compromised and are having tap in laundry. of course we will just fill jug from that and drink it anyway Re: Rainwater tanks 25Mar 11, 2008 5:26 pm i think our pump is made by 'onga' and has the mains diverter which is called a 'rainbank' (I think that is what it is called, but it is also by ONGA). there is a cheaper equivalent version done by orange pumps but i heard they are not as well made / durable. PM me if you want me to email you more specific info when i have it in front of me.
cheers Helen Re: Rainwater tanks 27Mar 11, 2008 7:27 pm Quote: haywgl wrote: 'Provide option for 2000 litre Colorbond Aquaplate round tank with auto top-up system, electric pressure pump and by-pass, connected to all sanitary flushing systems - $7,536' That sounds very expensive to me. We're getting a 5000 litre tank, with all those same connections and accessories for $5k. Belinda, We're also doing it after handover. Same as Ray, we chose the solar hot water instead of the tank as standard. It would definitely be cheaper to do it after handover. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Rainwater tanks 29Mar 12, 2008 9:01 am VJQuote: haywgl wrote: 'Provide option for 2000 litre Colorbond Aquaplate round tank with auto top-up system, electric pressure pump and by-pass, connected to all sanitary flushing systems - $7,536' That sounds very expensive to me. We're getting a 5000 litre tank, with all those same connections and accessories for $5k. Belinda, We're also doing it after handover. Same as Ray, we chose the solar hot water instead of the tank as standard. It would definitely be cheaper to do it after handover. Same here. Had the option with Carlisle Homes & chose the solar hot water as I believe the savings in the end will be more benificial compared with tanks. Looking to get a 2500 lt tank & pump once were moved in. Cheers, Mike. My Blog... http://ahouseonthehill.blogspot.com/ Re: Rainwater tanks 30Mar 12, 2008 9:42 am Hmmm we didn't get the option of a tank OR the gas boosted solar HWS with H3nley.. The tank was always an "option" if we wanted to pay $$$ for it...
We'll buy a tank after handover....no big deal for us atm. Re: Rainwater tanks 31Mar 12, 2008 12:37 pm Hi,
I think you either need to have a solar hot water system or the water tank... for $7k you may as well buy and install the water tank yourself after handover... it will end up being alot cheaper... gosh 7k is steap Re: Rainwater tanks 32Mar 12, 2008 7:24 pm We're getting both solar hot water and a 5000l water tank installed by the builder. Overall, it might be more expensive, but it'll get done at the same time and its simpler for the mortgage. Hello, I'm looking at getting some underground concrete tanks on a rural property (for drinking water), and, if levels work out, this will be a 'dry' system. The inlet… 0 40479 It's a good plan and friction losses are low at low velocity. Positive displacement pumps used as header pumps are simple, reliable, have high lift and work well with… 3 34423 |
