What has been your experience with this?
Thanks z
Browse Forums General Discussion 1 Jul 13, 2012 3:20 am Hi all, When I built back in the mid 90's, the builder ran the pipes through the slab (no problems there) and then ran them outside the wall (Ok by us as well). Now I've heard that builders use black PVC piping and run it through walls and over ceilings. My worry is that when i build that these will explode or deteriorate in time due to the very low temps in the Southern Highlands and flooding and water damage comes to be a major problem What has been your experience with this? Thanks z Re: Running Water Pipes through slabs and ceilings 2Jul 13, 2012 6:41 am I think the modern tube you are thinking opf is a product like Rehau, which is high density cross linked polythene. So what does that all mean? Pretty tough stuff. I would find something else to worry about before concerns of exploding pipoes. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Running Water Pipes through slabs and ceilings 3Jul 13, 2012 3:24 pm Hi Builderforlife, thank you for your quick reply. This is such a relief. I saw a house built a few years ago and the water pipes were nothing more than what I'd use for irrigating the garden bed, the connections were even the same . I was horrified. I'm relieved now that they are better quality. Out of curiosity, do these pipes have problems with rats or possums being able to chew through them easily? We have bush rats here that can chew through concrete, just about. Thanks z DIY, Home Maintenance & Repair im not convinced that its coming through the door. But aside from that I cant help anymore, you need to buy a moisture tester to trouble shoot it yourself or seek… 5 31388 I went to the displays and I prefer the higher 2340mm doors on the first floor matching the ground floor. In a lot of the display homes, the ground floor was 2700mm… 2 58573 Looking to get this narrow strip that leads into the carport concreted but worried if a stormwater pipe will be able to handle the weight of the concrete plus the weight… 0 69518 |
