Hi,
Today, a 10cm long centipede dropped through our evaporative cooler vent. This has happened once before as well. Is there anyone who could advise as to what to do to get rid of these centipedes?
Browse Forums General Discussion Re: Centipede through evaporative cooler vent 2Feb 26, 2025 9:40 am Hi, Today, a 10cm long centipede dropped through our evaporative cooler vent. This has happened once before as well. Is there anyone who could advise as to what to do to get rid of these centipedes? long term solution is to regularly use barrier spray outside your home Yeah, those old vents in 70s places are a bit weird. They don’t really connect to the wall cavity like body corp thinks — they just go straight through the wall.… 1 2267 Yeah, that’s a pretty common issue with older suburbs. If you’re going the private pole route, make sure your LV2 electrician checks clearance and Ausnet’s… 2 70894 DIY, Home Maintenance & Repair im not convinced that its coming through the door. But aside from that I cant help anymore, you need to buy a moisture tester to trouble shoot it yourself or seek… 5 31388 |
