Browse Forums General Discussion Re: Noisy neighbours (using the formal channels) 9Jan 04, 2023 4:29 pm i once had a rental tennants had dogs and cats defecating inside the house tennants were smoking inside the house estate agent didnt even tell me until vacating inspection which i attended agents admitted they knew, but didnt want to upset the tennants when i made a claim against their bond they brought out a list of complaints they had made to agent which i was unaware of some were warranty items relating to new kitchen and this was a high end, extremely large estate agents rental division Re: Noisy neighbours (using the formal channels) 10Jan 04, 2023 4:46 pm aussieta i once had a rental tennants had dogs and cats defecating inside the house tennants were smoking inside the house estate agent didnt even tell me until vacating inspection which i attended agents admitted they knew, but didnt want to upset the tennants when i made a claim against their bond they brought out a list of complaints they had made to agent which i was unaware of some were warranty items relating to new kitchen and this was a high end, extremely large estate agents rental division Yes, I suspect the real estate agent may be not doing a good job, and possibly not doing thoroguh rent inspections. I've heard (via my gossipy upstairs neighbour) that the owner isn't happy with the Real Estate agent but I don't know why. The owner may be in for an unpleasant surprise once he eventually sees the place. Re: Noisy neighbours (using the formal channels) 11Jan 11, 2023 8:26 pm How old is the building? the wall between the 2x apartments is called a party wall (its fire rated to protect one side from the other in the case of a fire) it is also required to RW + CTR Rating (sound rating). Quite often you find the builder sort of conveniently forgot to install the batts to achieve the required sound insulation. You might want to check if the wall meets the required standard. You may win by having the agent move on the current tenant only to have a midnight drummer move in! Check the sound rating first! We are Expert Consultant's, and we are here to help. Re: Noisy neighbours (using the formal channels) 12Jan 12, 2023 12:04 pm BuildingandLegal How old is the building? the wall between the 2x apartments is called a party wall (its fire rated to protect one side from the other in the case of a fire) it is also required to RW + CTR Rating (sound rating). Quite often you find the builder sort of conveniently forgot to install the batts to achieve the required sound insulation. You might want to check if the wall meets the required standard. You may win by having the agent move on the current tenant only to have a midnight drummer move in! Check the sound rating first! Thanks for the reply. The building is about 12 - 15 years old. It's a nice building but we already know that not everything was done as should have. Do you have any suggestions as to how I would find out what the CTR Rating requirement is, and then in turn, how I would find out whether the party wall meets that standard? (I'm prepared to cut a hole in the wall to find out. I've already invested in an endoscopic camera so I can inspect the inside of the walls and ceiling. I just need to know what I'm looking for. I've been considering getting blow insulation put in the walls, but I still need to do more research in case there is a better option. Re: Noisy neighbours (using the formal channels) 13Jan 12, 2023 1:11 pm aussieta i once had a rental tennants had dogs and cats defecating inside the house tennants were smoking inside the house estate agent didnt even tell me until vacating inspection which i attended agents admitted they knew, but didnt want to upset the tennants when i made a claim against their bond they brought out a list of complaints they had made to agent which i was unaware of some were warranty items relating to new kitchen and this was a high end, extremely large estate agents rental division Not at all uncommon. Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 10804 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14785 it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7581 |
