Browse Forums General Discussion Re: Neighbour trespassing on our property to remove plants a 16Jan 26, 2022 7:35 pm I think the issue here is the trespass and the damage of the OP’s garden. Often zero lot walls will have an easement for support and maintenance which resolves these issues. Your neighbour can’t dictate what you do with your land, they can’t cut trees on your property, they can’t trespass especially if permission has been denied. The zero lot wall should be zero maintenance for this reason, a rendered brick wall is zero maintenance, cutting your plants is not maintaining their wall. Painting their wall once a decade is maintenance. Your neighbour is a d*ck. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5907 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11829 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7063 |
