Browse Forums General Discussion Re: My house slab is in wrong size 3Mar 23, 2009 9:09 pm Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: My house slab is in wrong size 7Mar 23, 2009 9:25 pm Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: My house slab is in wrong size 10Mar 24, 2009 12:35 pm I remember reading in a previous post from a few months ago that the tolerance for frame overhang is 10mm but I can't find the post at the moment. Re: My house slab is in wrong size 11Mar 24, 2009 12:49 pm mrsnrub I remember reading in a previous post from a few months ago that the tolerance for frame overhang is 10mm but I can't find the post at the moment. Tollerance will depend on what size studs they are using. Houses can technically be built with 75 will studs. However you can not drill into or have any tolerance with this size. So i guess if you use 90mm studs then you can overhang 15mm if you dont not drill an holes in it, or dont plane the studs. Chances are that you will have to do one or the other (holes for cables and or planing to straighten wall). So i would not except more than 10mm in worst case provided 90mm studs are used. welcome to learning that colours vary in different lighting conditions. 1 3057 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18647 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16693 |
