Browse Forums General Discussion Re: Storm water connection 4Apr 04, 2020 8:09 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Storm water connection 6Apr 04, 2020 11:21 pm Plan attached - does it helps? Also checked with council they have advised there was enough fall on the block. Your builder might have deep cut done which caused level to mis match. How can I get this level info Confirmed From builder as I understand it should be builder’s responsibility to have levels worked out not mine. Yes charged system - builder said for downpipes he will have charged system and for surface drain he will have pit and pump as he will have split system. From your replies it seems I need to have pit n pump Is there any other way for storm drainage like adding more soil or concrete under waffle pod slab so it is bit higher and there will be enough fall for gravity fed pipes As slab thickness is 400mm Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8283 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7148 ![]() Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 11013 |
