Browse Forums General Discussion 1 Dec 12, 2018 11:38 am Just wondering if it is a requirement that render needs to be completed to reach this stage ( we have Hebel Panels ) we are on standard hia contract which states that cladding and external walls built , eaves and aluminium windows and doors fitted , no timber doors or windows to be fitted until brickwork is finished. Re: Lock up payment 2Dec 12, 2018 9:04 pm I had Hebel house built. I can’t tell you based on legalities of contract, just based on my experience. I looked at my old lock up inspection report just to check. The lower level was yet to be rendered. The upper level render was completed while the scaffolding was up. My facade had 2 colors so second color/additional coat was done later as there was access for this to be done later. Look around at local builds I think you’ll find this is pretty common. By the way- Are you having a private inspection with a building consultant for lock up stage?... if so you may as well ask the inspector. If not.... maybe think again. It’s an important time build stage as much will soon be covered up. Re: Lock up payment 4Dec 13, 2018 1:49 pm We had our lock up invoice before ground floor rendering was complete, if you have a acrylic render finish it will be one of the last items done as builder will want to minimize damage risk to finish when other trades are on site. I ran into trouble finding a lock that would fit my particular door, like your situation with your pivot door. I wanted a safe lock that couldn't be messed with easily. 4 25691 1 3401 nothing to do with salespeole. you'd do well to read and ccomprehend the post before bashing away at the keys with some negative comment again. 4 5048 |
