Browse Forums General Discussion 1 Mar 05, 2014 1:53 pm What is wrong with placing a roof truss so that it is supported on 3 walls other than just two? Thank you. Re: Roof Truss supported by 3 walls? 2Mar 05, 2014 6:18 pm Nothing,provided its engineered that way. Roof trusses are designed with cambers and other characteristics for specific loadings etc. eg.you couldn't put a tile roof on a truss system designed for iron,and visa versa because they are designed for a particular loading. another factor taken into account is the ceiling lining, the pitch of the roof, and the wind zoning,so when it all complete you end up with a flat ,level ceiling and a roof true in plane. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2429 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 13944 |
