Browse Forums General Discussion 1 Sep 16, 2008 3:34 pm Can someone give me the dimensions of their front load washer???
Height, width and depth. Thank you!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: dimensions of front load washer 2Sep 16, 2008 4:03 pm Ours is a Meile and the dimensions are
depth 60cm width 60 cm Height 85 cm The depth I gave you doesn't include hoses and cords so keep in mind space for those protuding aswell. Some protrude alot and some don't. Re: dimensions of front load washer 3Sep 16, 2008 4:07 pm Since Bosch introduced their front-loading models in Europe over 50 years ago, their washers and dryers have steadily been advancing and improving. Their machines are so advanced that it's the most energy efficient in America, using 76% less water and almost 72% less energy then conventional top-loading machines. It offers superior cleaning results and quieter operation. Bosch washers and dryers is the best you'll ever own do to the powerful combination of efficiency, performance, value and engineering.
-------------------- albertjames Foreclosed Homes Re: dimensions of front load washer 4Sep 16, 2008 4:20 pm Albert james are you measuring spam. I don't see any dimensions in your post. Re: dimensions of front load washer 5Sep 16, 2008 4:56 pm Thanks PK! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: dimensions of front load washer 6Sep 21, 2008 5:10 pm We were advised to be careful to ensure that there is enough room at the back of the space for the washer. Seems that sometimes the mearsurement is made at the front opening and the floor slopes up inside meaning that the back of the3 washer won't fit
Also be sure to specify taps and power are located under the bench for a front loader. regards sean Re: dimensions of front load washer 7Sep 21, 2008 5:14 pm Thanks Sean…I bought a top load instead.
My original idea would not have given me the extra space I was hoping for. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com I get an error message on my dishwasher (whirlpool ADG 7580) indicating that the water inlet is closed. I think there is a… 0 1921 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 5114 just ask a carpenter/ builder, if they are unsure they will get the engineer to advise. 1 2160 |
