Colorbond and CCTV
I have a colorbond roof, and RACV stated that sometimes CCTV cameras can't even be installed when that's the case.
Does anyone have experience running the required ethernet cables in that context? Right now the only reason I can think of that would make things a bit more complicated is that insulation on the eaves could make it harder when running the cables with a snake. But I am a complete beginner, so I might not be thinking straight.
And there should be NO insulation in your eaves as long as you are having a ventilated roof.
My cameras are POE, no need for an additional power cable
Its defiantly easier with POE
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
21/02/2024
Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you.
17/08/2023
1
Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust…
